Ir para o conteúdo principal
Removing the HP Elitebook 6930p Display Assembly
O que você precisa
  1. Removing the HP Elitebook 6930p Display Assembly, Battery Removal: passo 1, imagem 1 %32 Removing the HP Elitebook 6930p Display Assembly, Battery Removal: passo 1, imagem 2 %32 Removing the HP Elitebook 6930p Display Assembly, Battery Removal: passo 1, imagem 3 %32
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Removing the HP Elitebook 6930p Display Assembly, Keyboard: passo 2, imagem 1 %32 Removing the HP Elitebook 6930p Display Assembly, Keyboard: passo 2, imagem 2 %32 Removing the HP Elitebook 6930p Display Assembly, Keyboard: passo 2, imagem 3 %32
    • Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
    • Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
    • Slide the retention clips toward the keyboard to release the keyboard
  3. Removing the HP Elitebook 6930p Display Assembly: passo 3, imagem 1 %32 Removing the HP Elitebook 6930p Display Assembly: passo 3, imagem 2 %32 Removing the HP Elitebook 6930p Display Assembly: passo 3, imagem 3 %32
    • Use a plastic pry tool to lift the rear edge of the keyboard.
    • Pull the keyboard slightly towards the display to disengage the tabs along the front of the keyboard from the laptop palm rest.
    • Lift the keyboard up to reveal the ribbon connectors
    After loosening the four moveable tabs at the screen end you simply pull slightly to the right to loosen the left side and then up to loose the five tabs in the lower end, then flip keyboard over so keys face the screen.
    e5frog - Responder
  4. Removing the HP Elitebook 6930p Display Assembly: passo 4, imagem 1 %32 Removing the HP Elitebook 6930p Display Assembly: passo 4, imagem 2 %32 Removing the HP Elitebook 6930p Display Assembly: passo 4, imagem 3 %32
    • Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable
    • Release the smaller ribbon cable by lifting up the white retainer
    • I found it easier to reinstall both cables with the new keyboard resting on the back edge
    There is no need at all to loosen any ribbon cables, after flipping keyboard so it faces keys against screen you can simply remove the RAM. Don't fiddle with the ribbon cables.
    e5frog - Responder
    Unless, of course, that your actually replacing the keyboard! In which case, remember to keep that rubber pointing device for replacing the one that you’ll probably eventually lose.
    Dennis - Responder
  5. Removing the HP Elitebook 6930p Display Assembly, Switch Cover: passo 5, imagem 1 %32 Removing the HP Elitebook 6930p Display Assembly, Switch Cover: passo 5, imagem 2 %32 Removing the HP Elitebook 6930p Display Assembly, Switch Cover: passo 5, imagem 3 %32
    • Remove the two M2.0×4.0 broad-head screws.
    • Remove the three Torx T8 M2.5×7.0 screws.
  6. Removing the HP Elitebook 6930p Display Assembly: passo 6, imagem 1 %32 Removing the HP Elitebook 6930p Display Assembly: passo 6, imagem 2 %32 Removing the HP Elitebook 6930p Display Assembly: passo 6, imagem 3 %32
    • Turn the computer over with the front toward you and the open the computer as far as possible.
    • Release the ZIF connector for the power button board cable.
    • Remove the switch cover by lifting it straight up and flip it forward.
    • Release the ZIF connector for the LED board cable.
  7. Removing the HP Elitebook 6930p Display Assembly, Display Assembly: passo 7, imagem 1 %32 Removing the HP Elitebook 6930p Display Assembly, Display Assembly: passo 7, imagem 2 %32
    • Close the lid and turn the laptop so the rear is facing you
    • Locate and remove the two Torx T8 2.5×7.0 screws at each corner
    • The screws may have rubber caps over them. If so remove with a spudger or similar tool.
  8. Removing the HP Elitebook 6930p Display Assembly: passo 8, imagem 1 %32 Removing the HP Elitebook 6930p Display Assembly: passo 8, imagem 2 %32
    • With the laptop upside down, locate and remove the two Torx T8 2.5×7.0 screws.
  9. Removing the HP Elitebook 6930p Display Assembly: passo 9, imagem 1 %32 Removing the HP Elitebook 6930p Display Assembly: passo 9, imagem 2 %32 Removing the HP Elitebook 6930p Display Assembly: passo 9, imagem 3 %32
    • Turn the computer right-side up with the front toward you and open the computer lid past 90 degrees.
    • Locate and disconnect the display panel cable.
    • Locate and disconnect the microphone cable.
    • Locate and disconnect the webcam cable.
    • Locate and disconnect the 3 antenna cables.
    • Unclip the antenna cables from the retaining clips.
    • NOTE There are 2 antenna cables that go from the display assembly through the hole shown and connect to the WWAN (3G) WiFi card if it is installed. In my case they were just threaded into the hole to make things tidy as I didn't have a WWAN card.
  10. Removing the HP Elitebook 6930p Display Assembly: passo 10, imagem 1 %32 Removing the HP Elitebook 6930p Display Assembly: passo 10, imagem 2 %32
    • The display assembly will be unsupported when the following screws are removed. To prevent damage support the display before removing the screws.
    • Remove the two T8 2.5×7.0 screws holding the display assembly to the laptop.
    • Lift the display assembly straight up to remove it from the laptop.
Conclusão
11 outras pessoas executaram este guia.
Richdave
Membro desde: 04/09/10
32.063 Reputação
Autoria de 30 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.534 guias
Um comentário
muy útil el aporte
Emilio Zelaya - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 39
Duração total: 15,673
