Ir para o conteúdo principal
Removing the HP Compaq dx2000MT Optical (CD) Drive
O que você precisa
  1. Removing the HP Compaq dx2000MT Optical (CD) Drive, Removing the HP Compaq dx2000MT Case Doors: passo 1, imagem 1 %32
    • Turn off your computer and remove the power cable by pulling it straight out of its socket.
  2. Removing the HP Compaq dx2000MT Optical (CD) Drive: passo 2, imagem 1 %32 Removing the HP Compaq dx2000MT Optical (CD) Drive: passo 2, imagem 2 %32
    • Remove the two Phillips #2 screws that secure the case door to the device.
  3. Removing the HP Compaq dx2000MT Optical (CD) Drive: passo 3, imagem 1 %32 Removing the HP Compaq dx2000MT Optical (CD) Drive: passo 3, imagem 2 %32 Removing the HP Compaq dx2000MT Optical (CD) Drive: passo 3, imagem 3 %32
    • Remove the side case door by pushing towards the rear of the device with your hand.
    • This may take considerable force so keep pushing!
    • Once you slide the door back, remove it by pulling it outwards from the device.
  4. Removing the HP Compaq dx2000MT Optical (CD) Drive: passo 4, imagem 1 %32 Removing the HP Compaq dx2000MT Optical (CD) Drive: passo 4, imagem 2 %32 Removing the HP Compaq dx2000MT Optical (CD) Drive: passo 4, imagem 3 %32
    • Once again, this may take considerable force.
  5. Removing the HP Compaq dx2000MT Optical (CD) Drive, Optical (CD) Drive: passo 5, imagem 1 %32 Removing the HP Compaq dx2000MT Optical (CD) Drive, Optical (CD) Drive: passo 5, imagem 2 %32 Removing the HP Compaq dx2000MT Optical (CD) Drive, Optical (CD) Drive: passo 5, imagem 3 %32
    • Remove the IDE data cable and the power cable from the optical drive by pulling away from the drive.
  6. Removing the HP Compaq dx2000MT Optical (CD) Drive: passo 6, imagem 1 %32 Removing the HP Compaq dx2000MT Optical (CD) Drive: passo 6, imagem 2 %32
    • Remove the 2 Torx T15 screws holding the optical drive in place.
  7. Removing the HP Compaq dx2000MT Optical (CD) Drive: passo 7, imagem 1 %32 Removing the HP Compaq dx2000MT Optical (CD) Drive: passo 7, imagem 2 %32
    • Remove the other 2 Torx T15 screws holding the other side of the drive in place.
  8. Removing the HP Compaq dx2000MT Optical (CD) Drive: passo 8, imagem 1 %32 Removing the HP Compaq dx2000MT Optical (CD) Drive: passo 8, imagem 2 %32 Removing the HP Compaq dx2000MT Optical (CD) Drive: passo 8, imagem 3 %32
    • Remove the optical drive by sliding it out the front of the device.
Conclusão
Logan Pace
Membro desde: 10/12/11
2.278 Reputação
Autoria de 9 guias
Equipe
Cal Poly, Team 17-16, Regan Fall 2011 Membro de Cal Poly, Team 17-16, Regan Fall 2011
CPSU-REGAN-F11S17G16
Membros da 4
Autoria de 17 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 12
Duração total: 1,508
