Ir para o conteúdo principal
Removing the Dell Inspiron 1150 Optical Drive (Based on Dell Manual)
O que você precisa
  1. Removing the Dell Inspiron 1150 Optical Drive (Based on Dell Manual), Removing Dell Inspiron 1150 Battery: passo 1, imagem 1 %32 Removing the Dell Inspiron 1150 Optical Drive (Based on Dell Manual), Removing Dell Inspiron 1150 Battery: passo 1, imagem 2 %32 Removing the Dell Inspiron 1150 Optical Drive (Based on Dell Manual), Removing Dell Inspiron 1150 Battery: passo 1, imagem 3 %32
    • Place the laptop upside down on a clean, flat surface.
    • Locate the battery release button with the padlock symbol above it.
    • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
    • The battery is now released from the battery compartment.
    • Gently remove the battery from the side of the laptop.
  2. Removing the Dell Inspiron 1150 Optical Drive (Based on Dell Manual), Optical Drive (Based on Dell Service Manual): passo 2, imagem 1 %32 Removing the Dell Inspiron 1150 Optical Drive (Based on Dell Manual), Optical Drive (Based on Dell Service Manual): passo 2, imagem 2 %32 Removing the Dell Inspiron 1150 Optical Drive (Based on Dell Manual), Optical Drive (Based on Dell Service Manual): passo 2, imagem 3 %32
    • Place laptop upsid down on a clean flat work surface.
    • Remove the Philips M2.5 x 8 mm screw
    • Loosen the screw that holds the memory compartment closed
    • remove the memory module compartment cover
    • Press the Optical Drive release lever to the right and the optical drive should slide out of the case
Conclusão
Richdave
Membro desde: 04/09/10
32.081 Reputação
Autoria de 30 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.535 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 509
