Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
O que você precisa
Place the laptop upside down on a clean, flat surface.
Locate the battery release button with the padlock symbol above it.
Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
Gently remove the battery from the side of the laptop.
Turn the laptop upside down and locate the panel labeled C
Unscrew the single screw holding the cover in place.
Lift up the cover and remove it to expose the Modem Card.
