Ir para o conteúdo principal
Removing the Dell Inspiron 1150 Modem Card
O que você precisa
  1. Removing the Dell Inspiron 1150 Modem Card, Removing Dell Inspiron 1150 Battery: passo 1, imagem 1 %32 Removing the Dell Inspiron 1150 Modem Card, Removing Dell Inspiron 1150 Battery: passo 1, imagem 2 %32 Removing the Dell Inspiron 1150 Modem Card, Removing Dell Inspiron 1150 Battery: passo 1, imagem 3 %32
    • Place the laptop upside down on a clean, flat surface.
    • Locate the battery release button with the padlock symbol above it.
    • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
    • The battery is now released from the battery compartment.
    • Gently remove the battery from the side of the laptop.
  2. Removing the Dell Inspiron 1150 Modem Card, Modem Card: passo 2, imagem 1 %32 Removing the Dell Inspiron 1150 Modem Card, Modem Card: passo 2, imagem 2 %32 Removing the Dell Inspiron 1150 Modem Card, Modem Card: passo 2, imagem 3 %32
    • Turn the laptop upside down and locate the panel labeled C
    • Unscrew the single screw holding the cover in place.
    • Lift up the cover and remove it to expose the Modem Card.
  3. Removing the Dell Inspiron 1150 Modem Card: passo 3, imagem 1 %32 Removing the Dell Inspiron 1150 Modem Card: passo 3, imagem 2 %32
    • Locate the Modem card.
    • Remove the screws.
  4. Removing the Dell Inspiron 1150 Modem Card: passo 4, imagem 1 %32 Removing the Dell Inspiron 1150 Modem Card: passo 4, imagem 2 %32
    • Pull tab to lift the card out of the connector on the main board.
    • Disconnect the cable attached to the left edge of the Modem card
Linha de Chegada
Lauren
Membro desde: 04/25/10
4 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 16-2, Maness Spring 2010 Membro de Cal Poly, Team 16-2, Maness Spring 2010
CPSU-MANESS-S10S16G2
Membros da 4
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 4,503
