Ir para o conteúdo principal
Removing the Dell Inspiron 1150 Keyboard
O que você precisa
  1. Removing the Dell Inspiron 1150 Keyboard, Removing Dell Inspiron 1150 Battery: passo 1, imagem 1 %32 Removing the Dell Inspiron 1150 Keyboard, Removing Dell Inspiron 1150 Battery: passo 1, imagem 2 %32 Removing the Dell Inspiron 1150 Keyboard, Removing Dell Inspiron 1150 Battery: passo 1, imagem 3 %32
    • Place the laptop upside down on a clean, flat surface.
    • Locate the battery release button with the padlock symbol above it.
    • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
    • The battery is now released from the battery compartment.
    • Gently remove the battery from the side of the laptop.
  2. Removing the Dell Inspiron 1150 Keyboard, Keyboard: passo 2, imagem 1 %32 Removing the Dell Inspiron 1150 Keyboard, Keyboard: passo 2, imagem 2 %32 Removing the Dell Inspiron 1150 Keyboard, Keyboard: passo 2, imagem 3 %32
    • Use a spudger to lift the notched right edge of the hinge cover, and pry it loose
    • You need to lay the LCD screen down flat to allow the hinge cover to be lifted off
    • Lift the hinge cover off and set aside
  3. Removing the Dell Inspiron 1150 Keyboard: passo 3, imagem 1 %32 Removing the Dell Inspiron 1150 Keyboard: passo 3, imagem 2 %32 Removing the Dell Inspiron 1150 Keyboard: passo 3, imagem 3 %32
    • Remove 4ea M2 x 3mm keyboard screws
    • Lift up keyboard from the rear to expose the connector below
    • Disconnect the keyboard ribbon cable from the mother board
Conclusão
Uma outra pessoa concluiu este guia.
Richdave
Membro desde: 04/09/10
32.063 Reputação
Autoria de 30 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.528 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 867
