Ir para o conteúdo principal
Removing the Behringer Eurolive B212D Electronics Box
O que você precisa
  1. Removing the Behringer Eurolive B212D Electronics Box, Removing the Behringer Eurolive B212D Electronics Box: passo 1, imagem 1 %32
    • CAUTION: Unplug your speaker from the power outlet.
    • Remove the 8 Phillips screws from the back of the speaker.
    Eurolive B212d back plate requirement
    Ashok Ahlawat - Responder
  2. Removing the Behringer Eurolive B212D Electronics Box: passo 2, imagem 1 %32
    • Carefully remove the back panel, lifting out the metal electronics-box with it.
    • To avoid damaging your speaker, remove slowly, as there is still a wire attached from the electronics box to the speaker.
Conclusão
3 outras pessoas executaram este guia.
Troy W. Weber
Membro desde: 03/29/12
1.431 Reputação
Autoria de 6 guias
2 comentários
I want to buy the hole back panel, but I don't where?, tell me
miguelangelvera63 - Responder
I will wait for answer
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 14
Últimos 30 dias: 27
Duração total: 3,544
