Perigo
Potencialmente perigoso
Se este procedimento não for seguido corretamente, podem ocorrer ferimentos. Use cautela e siga todos os avisos.
Perigo
Introdução
Your B212D contains a case filled with a metal box that contains all the electronics, except for the speakers. You will be removing this electronics box to access the case's internal space - you know, in case you need to stash $1,000,000 dollars in there to hide it from the CIA! :)
Peças
Não são necessárias peças.
  1. Unplug your speaker from the power outlet.
    • Unplug your speaker from the power outlet.
    • Remove the 8 Phillips screws from the back of the speaker.
  2. Free shipping on all orders over US$100 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  3. Carefully remove the back panel, lifting out the metal electronics-box with it.
    • Carefully remove the back panel, lifting out the metal electronics-box with it.
    • To avoid damaging your speaker, remove slowly, as there is still a wire attached from the electronics box to the speaker.
Conclusão
Uma outra pessoa concluiu este guia.
gameslammer7
888 reputação
6 Guides authored
I want to buy the hole back panel, but I don't where?, tell me
miguelangelvera63 - Responder
I will wait for answer
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 26
Todo: 2,399
