Introdução
This guide will explain how to remove the display hinge. The tools required for this section are the spudger and the PH 2 screwdriver.
O que você precisa
Flip the Cinema Display so it is on its face and the feet are pointed away from you.
Using the PH 2 screwdriver, unscrew the three feet screws (9.52 x 4.43 mm).
Remove the back foot from the hinge mount by gently pulling it upwards.
4 outras pessoas executaram este guia.
1Comentário do guia
in 2023 where can I get a replacement stand?
