Ir para o conteúdo principal
Removing fans
O que você precisa
  1. Removing fans, Remove screws from bottom of laptop.: passo 1, imagem 1 %32 Removing fans, Remove screws from bottom of laptop.: passo 1, imagem 2 %32
    • Flip the computer over to access the screws on the bottom.
    • Remove 8 black, 7mm PH0 screws (M2 x L7).
    • Note: Virtually all the other screws for this computer are PH1 screws which may get stripped when using a smaller screwdriver, but these screws require a Philips PH0 driver.
    • Pry up the clips/latches and then remove the lower case. Start at the front (four clips), then sides (three clips each side) and back (four clips) - there is also one clip in the middle of the case.
  2. Removing fans, Remove the system board mylar: passo 3, imagem 1 %32 Removing fans, Remove the system board mylar: passo 3, imagem 2 %32
    • Remove the system board mylar.
    • Note: Retain the system board mylar and reuse it when reassembling the computer. Replace the system board mylar only if it is damaged.
  3. Removing fans, Disconnect tape and cables: passo 4, imagem 1 %32
    • (1) Peel off the thermal DIMM plate tape from the system board.
    • (2-3) Lift flap and disconnect the I/O board cable from the system board.
    • (2-3) Lift flap and disconnect the audio FPC cable from the system board.
    • (2-3) Lift flap and disconnect the hinge cap lightingbar cable from the system board.
    • Note: my machine did not have the DIMM plate tape or the cable in the upper right.
  4. Removing fans, Disconnect the fan cables: passo 5, imagem 1 %32
    • Disconnect the three fan cables from the system board by lifting away from board.
  5. Removing fans, Remove screws and fans: passo 6, imagem 1 %32
    • Remove 7 black 6mm PH1 screws (M2 x L6) holding the fans.
    • Note: Virtually all the screws for this computer are PH1 screws which may get stripped if you use a smaller screwdriver.
    • Remove tape from fans - possibly using gentle heat
    • Remove the fans - be careful of Wi-Fi antenna cables around top left fan and speaker cable around small bottom right fan.
Conclusão
johann beda
Membro desde: 09/13/10
3.428 Reputação
Autoria de 15 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 15
Ao todo: 69
