Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
O que você precisa
Place the plastic opening tool in the bottom corner of the phone in the crevice between the flap to remove the cover.
Place the phone face down on a flat smooth surface so that the camera, logos, and speaker face up.
Using the provided notch on the bottom of the back cover, insert a plastic opening tool and lift upwards to remove the back cover of the phone.
Flip the phone over and remove the Sony Ericsson sticker that is over the phone's ear speaker.
Using a T5 screwdriver, loosen and remove the two screws under the Sony Ericsson sticker by turning them counterclockwise.
After removing the speaker, the keypad will be free to move. If the phone is lying flat on its back, it is connected in the middle right side of the phone. This connection can be seen in the second picture.
To remove the keypad, pull gently at the connection until the keypad "pops" off.
The third photo in this step will show a closer look at the keypad connection.
Uma outra pessoa concluiu este guia.
