Ir para o conteúdo principal
Removing Solid-State Drive (SSD) shielding
O que você precisa
  1. Removing Solid-State Drive (SSD) shielding, Remove screws from bottom of laptop.: passo 1, imagem 1 %32 Removing Solid-State Drive (SSD) shielding, Remove screws from bottom of laptop.: passo 1, imagem 2 %32
    • Flip the computer over to access the screws on the bottom.
    • Remove 8 black, 7mm PH0 screws (M2 x L7).
    • Note: Virtually all the other screws for this computer are PH1 screws which may get stripped when using a smaller screwdriver, but these screws require a Philips PH0 driver.
    • Pry up the clips/latches and then remove the lower case. Start at the front (four clips), then sides (three clips each side) and back (four clips) - there is also one clip in the middle of the case.
  2. Removing Solid-State Drive (SSD) shielding, Disconnect battery cable: passo 3, imagem 1 %32
    • Almost anything that is done with a computer is safer if the battery is disconnected, so it is good to do that now.
    • Disconnect the battery pack cable from the system board using fingernails or a pry bar. Use your fingernails to pull the connector to unplug it. Do not pull the cable. It can be very tight. I used a 3.5 mm flathead screwdriver to carefully push the side plastic edges down towards the battery. Do not knock any of the components on the board.
  3. Removing Solid-State Drive (SSD) shielding, Remove the system board mylar: passo 4, imagem 1 %32 Removing Solid-State Drive (SSD) shielding, Remove the system board mylar: passo 4, imagem 2 %32
    • Remove the system board mylar.
    • Note: Retain the system board mylar and reuse it when reassembling the computer. Replace the system board mylar only if it is damaged.
  4. Removing Solid-State Drive (SSD) shielding, Remove the solid-state drive (SSD) shielding: passo 5, imagem 1 %32
    • Remove 4 black PH1 screws (M2 x L4) and then remove the SSD shielding.
    • Note: Virtually all the screws for this computer are PH1 screws which may get stripped if you use a smaller screwdriver.
Conclusão
johann beda
Membro desde: 09/13/10
3.428 Reputação
Autoria de 15 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 18
Ao todo: 56
