Ir para o conteúdo principal
Removing Samsung DVD-P230 Motherboard
O que você precisa
  1. Removing Samsung DVD-P230 Motherboard, Outer Cover & Faceplate: passo 1, imagem 1 %32 Removing Samsung DVD-P230 Motherboard, Outer Cover & Faceplate: passo 1, imagem 2 %32 Removing Samsung DVD-P230 Motherboard, Outer Cover & Faceplate: passo 1, imagem 3 %32
    • Open the tray by pressing the eject button
    • Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
  2. Removing Samsung DVD-P230 Motherboard: passo 2, imagem 1 %32
    • Press the eject button to insert the tray
    • After the tray is closed unplug DVD player
  3. Removing Samsung DVD-P230 Motherboard: passo 3, imagem 1 %32
    • Unscrew the 3 screws in the back.
  4. Removing Samsung DVD-P230 Motherboard: passo 4, imagem 1 %32 Removing Samsung DVD-P230 Motherboard: passo 4, imagem 2 %32
    • Pull the outer case upward and then towards you.
  5. Removing Samsung DVD-P230 Motherboard: passo 5, imagem 1 %32 Removing Samsung DVD-P230 Motherboard: passo 5, imagem 2 %32 Removing Samsung DVD-P230 Motherboard: passo 5, imagem 3 %32
    • There are six symmetrically placed tabs holding in the front faceplate. Unhook these six tabs to loosen the faceplate.
  6. Removing Samsung DVD-P230 Motherboard: passo 6, imagem 1 %32 Removing Samsung DVD-P230 Motherboard: passo 6, imagem 2 %32
    • Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously.
  7. Removing Samsung DVD-P230 Motherboard, Power Cord: passo 7, imagem 1 %32 Removing Samsung DVD-P230 Motherboard, Power Cord: passo 7, imagem 2 %32 Removing Samsung DVD-P230 Motherboard, Power Cord: passo 7, imagem 3 %32
    • Locate the white clip that attaches the cord to the motherboard
    • Grasp clip and squeeze to release
    • Lift up and remove power cord
    • Slide cord mount from outer case
  8. Removing Samsung DVD-P230 Motherboard, Tray: passo 8, imagem 1 %32 Removing Samsung DVD-P230 Motherboard, Tray: passo 8, imagem 2 %32 Removing Samsung DVD-P230 Motherboard, Tray: passo 8, imagem 3 %32
    • Remove the three screws holding in the DVD tray
  9. Removing Samsung DVD-P230 Motherboard: passo 9, imagem 1 %32 Removing Samsung DVD-P230 Motherboard: passo 9, imagem 2 %32
    • Remove the power cord and first two ribbons by pulling them directly out of their sockets.
  10. Removing Samsung DVD-P230 Motherboard: passo 10, imagem 1 %32 Removing Samsung DVD-P230 Motherboard: passo 10, imagem 2 %32
    • Gently lift the DVD tray off of the motherboard.
  11. Removing Samsung DVD-P230 Motherboard, Motherboard: passo 11, imagem 1 %32 Removing Samsung DVD-P230 Motherboard, Motherboard: passo 11, imagem 2 %32
    • Unscrew the 2 screws on the motherboard
    • Unscrew the 2 screws on the back
  12. Removing Samsung DVD-P230 Motherboard: passo 12, imagem 1 %32 Removing Samsung DVD-P230 Motherboard: passo 12, imagem 2 %32 Removing Samsung DVD-P230 Motherboard: passo 12, imagem 3 %32
    • Disconnect the wires and ribbon by pulling them out of their respective connections
  13. Removing Samsung DVD-P230 Motherboard: passo 13, imagem 1 %32 Removing Samsung DVD-P230 Motherboard: passo 13, imagem 2 %32
    • Lift board up and out of the lower case
Conclusão
Uma outra pessoa concluiu este guia.
Mitchell Hart
Membro desde: 01/21/11
903 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 3-30, Regan Winter 2011 Membro de Cal Poly, Team 3-30, Regan Winter 2011
CPSU-REGAN-W11S3G30
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 3,232
