Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
There are 2 RAM slots in the 6930p Laptop. One is the expansion slot and accessible from the underside of the device, the other is the default location for factory installed RAM and is located under the keyboard. This guide focuses on the RAM slot under the keyboard.
O que você precisa
Flip laptop over and locate the battery release button
Push release button to the left to release battery and gently pull battery from the laptop
Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
Slide the retention clips toward the keyboard to release the keyboard
Locate RAM module
Push metal tabs outwards away from the RAM module to release it.
The RAM module will spring up and can be removed from the RAM slot.
21 outras pessoas executaram este guia.
7 comentários
HP Elitebook 6930p. Huh !!!!
Desingn constructor is the largest manufacturer idiot. Put one memory slot inside, located under the keyboard denotes an unparalleled stupidity.
Thanks for your splendid guide. I don't have a plastic pry tool. A bass guitar plectrum works just as well though. The whole job took under 10 mins to complete. I now have X2, 2GB memory cards installed. This is plenty to run Manjaro JWM 16,04.1. It boots up only using 180 MB of RAM - perfect.
Great guide. Trying to part out computer and couldn't figure out where other memory slot located. Agree dumb place for it.
the ram is acessible through the door in the middle, need to unscrew 2 screws LOL
