Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Removing Playstation 2 Slimline SCPH-7500x Outer Shell
O que você precisa
    • Turn off the PlayStation 2 (or PS2) and carefully unplug from the power source. Check to see there are no discs inside the console before flipping the game system upside-down.
  1. Removing Playstation 2 Slimline SCPH-7500x Outer Shell: passo 2, imagem 1 %32
    • Locate the six feet on the bottom of the PS2.
    • Five of the feet are in plain sight and one of the feet is located under the black void sticker on the bottom of the device.
    • Some versions of the console, such as the PAL Version, may not have this sticker. In this case, the foot or even the screw should be in plain sight.
  2. Removing Playstation 2 Slimline SCPH-7500x Outer Shell: passo 3, imagem 1 %32 Removing Playstation 2 Slimline SCPH-7500x Outer Shell: passo 3, imagem 2 %32 Removing Playstation 2 Slimline SCPH-7500x Outer Shell: passo 3, imagem 3 %32
    • Pry apart the five visible feet from the bottom of the device using a spudger, or your fingers.
  3. Removing Playstation 2 Slimline SCPH-7500x Outer Shell: passo 4, imagem 1 %32 Removing Playstation 2 Slimline SCPH-7500x Outer Shell: passo 4, imagem 2 %32
    • The sixth foot is located under the black VOID sticker. Remove the sticker before removing the foot underneath.
  4. Removing Playstation 2 Slimline SCPH-7500x Outer Shell: passo 5, imagem 1 %32 Removing Playstation 2 Slimline SCPH-7500x Outer Shell: passo 5, imagem 2 %32 Removing Playstation 2 Slimline SCPH-7500x Outer Shell: passo 5, imagem 3 %32
    • After all of the feet have been removed, Use a Phillips #1 screwdriver to remove the six 4.0mm screws from the base of the PS2.
  5. Removing Playstation 2 Slimline SCPH-7500x Outer Shell: passo 6, imagem 1 %32 Removing Playstation 2 Slimline SCPH-7500x Outer Shell: passo 6, imagem 2 %32 Removing Playstation 2 Slimline SCPH-7500x Outer Shell: passo 6, imagem 3 %32
    • Once all of the screws have been removed, pull apart the top plastic cover from the bottom plastic cover. Start by lifting the side containing the power cable and Ethernet port. Then, lift the opposite side to fully separate. It will take force to pull apart the two halves.
  6. Removing Playstation 2 Slimline SCPH-7500x Outer Shell: passo 7, imagem 1 %32
    • If done correctly, you should have a fully detached plastic backing, revealing the electronic components of the PlayStation 2.
Conclusão
9 outras pessoas executaram este guia.
Jared Hirata
Membro desde: 04/09/13
880 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 17-4, Regan Spring 2013 Membro de Cal Poly, Team 17-4, Regan Spring 2013
CPSU-REGAN-S13S17G4
Membros da 3
Autoria de 28 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 2,532
