Ir para o conteúdo principal
Removing Philips Wake-Up HF3520 Inner Lamp Screen
O que você precisa
    1. Removing Philips Wake-Up HF3520 Inner Lamp Screen, Start: passo 1, imagem 1 %32 Removing Philips Wake-Up HF3520 Inner Lamp Screen, Start: passo 1, imagem 2 %32 Removing Philips Wake-Up HF3520 Inner Lamp Screen, Start: passo 1, imagem 3 %32
      • There is a screw under the shiny UL sticker. Remove the sticker or pierce it to unscrew and remove this bottom panel.
      • There are two tabs holding the panel into the back of the clock/light. If the panel does not come out easily, gently wiggle a flat-blade screwdriver or spudger in the grill next to where the screw was to loosen it.
      Pergunte ao FixBot
      Comentar
      • Flipping the light on its back will present a small section of the bezel that can be pried out. It is a small plastic strip with hooks that have to be disengaged to be removed.
      • Push the blade of the jimmy directly into the crevice above the cover. Once it has gone a few millimeters, tilt it to lift the cover slightly.
      • Slide the jimmy to the right side and press it against the latch to release it. Do the same for the left side.
      • A "jimmy" is essentially a small putty knife with a strong, slightly flexible blade.
      • Note: Despite the images shown, a spudger is not recommended as the fit is so tight it takes quite a bit of effort to insert and slide.
      Pergunte ao FixBot
      Comentar
    2. Removing Philips Wake-Up HF3520 Inner Lamp Screen, Remove the button ring: passo 3, imagem 1 %32 Removing Philips Wake-Up HF3520 Inner Lamp Screen, Remove the button ring: passo 3, imagem 2 %32 Removing Philips Wake-Up HF3520 Inner Lamp Screen, Remove the button ring: passo 3, imagem 3 %32
      • We can finally unscrew two more Philips head screws to remove the button ring.
      • Tip: Lift one end of the ring, tilting it toward the back of the alarm clock. That will get the hooks out from under the rear rim so you can start removing it..
      Pergunte ao FixBot
      Comentar
    3. Removing Philips Wake-Up HF3520 Inner Lamp Screen, Front screen shield: passo 4, imagem 1 %32 Removing Philips Wake-Up HF3520 Inner Lamp Screen, Front screen shield: passo 4, imagem 2 %32
      • Now the six screws holding the front screen need to be removed and the screen can be pulled away to the front.
      • Take care not to damage the internal screen.
      Pergunte ao FixBot
      Comentar
    4. Removing Philips Wake-Up HF3520 Inner Lamp Screen, Inner screen screws: passo 5, imagem 1 %32
      • Remove the four screws holding the inner screen assembly in place.
      • Screw organization note for later: these screws have pointed ends
      Pergunte ao FixBot
      Comentar
    5. Removing Philips Wake-Up HF3520 Inner Lamp Screen, Inner screen assembly: passo 6, imagem 1 %32 Removing Philips Wake-Up HF3520 Inner Lamp Screen, Inner screen assembly: passo 6, imagem 2 %32 Removing Philips Wake-Up HF3520 Inner Lamp Screen, Inner screen assembly: passo 6, imagem 3 %32
      • There are two tabs that hold the assembly in on the bottom left and right sides.
      • Using a jimmy — or any flexible, flat, metal tool, such as a putty knife — press the back tabs inwards to release.
      • Note: Do not be surprised if you have to push hard.
      • Tip: If you pull the inner screen assembly out slightly, you can see the tabs better. However, it puts pressure on the latches making them more difficult to release.
      Pergunte ao FixBot
      Comentar
    6. Removing Philips Wake-Up HF3520 Inner Lamp Screen, Remove back cover (Optional but recommended): passo 7, imagem 1 %32 Removing Philips Wake-Up HF3520 Inner Lamp Screen, Remove back cover (Optional but recommended): passo 7, imagem 2 %32
      • Disconnect the speaker from the main circuit board.
      • The antenna (a long white wire) has a fragile solder connection to the main circuit board and care should be taken to not yank upon it.
      • Loosen the screw and washer inside the back cover by the speaker and unwrap the antenna wire that was pinned underneath. Pull the antenna all the way through so the back cover can be removed.
      • Alternately, you may simply pull only some of it through so that the wire is slack enough that the solder joint is at no risk.
      • Caution: The speaker and the buzzer connectors are the same so be careful when reassembling.
      Pergunte ao FixBot
      Comentar
    1. Removing Philips Wake-Up HF3520 Inner Lamp Screen, Remove the Screen: passo 8, imagem 1 %32 Removing Philips Wake-Up HF3520 Inner Lamp Screen, Remove the Screen: passo 8, imagem 2 %32
      • At the base of the domed panel with holes there are two screws. Remove them to release the screen.
      • Set screen panel aside for safe keeping.
      Pergunte ao FixBot
      Comentar
Conclusão
hackerb9
Membro desde: 02/19/16
312 Reputação
Autoria de 2 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 30
Ao todo: 543
