Introdução
This guide will walk you through disassembling the top and side panels of the device. You will need to obtain a Phillips #2 head screwdriver and a plastic opening tool before you start.
O que você precisa
Remove the five 9 mm #2 Phillips screws from the side panel nearest the power button.
Repeat the process for the opposite panel.
Remove the two 15 mm #2 Phillips screws from the back of the top panel.
Remove the middle 10mm #2 Phillips screw from the back of the top panel.
Swing the back half of the panel slightly away from the unit. Then, starting at the top back corner, slide plastic opening tool through the created gap from back to front. The panel should pop off. Repeat the process on the opposite panel.
Looking in through the side nearest the power button, use your fingers to pull the white ribbon connection toward you, away from the rear circuit board.
Remove the top panel. You will need to slightly bend the plastic tab outwards, to undo the clasp that is attached to the top.
