Ir para o conteúdo principal
Removing Panasonic DVD-RV31 Player Motherboard
O que você precisa
  1. Removing Panasonic DVD-RV31 Player Motherboard, Disk Tray Cover: passo 1, imagem 1 %32
    • Eject the disk tray from the DVD player before removing power supply.
  2. Removing Panasonic DVD-RV31 Player Motherboard: passo 2, imagem 1 %32
    • Evenly lift upward on the disk tray front cover (not slanted, as pictured). This will allow for easier disassembly of the player.
  3. Removing Panasonic DVD-RV31 Player Motherboard, Outer Case: passo 3, imagem 1 %32 Removing Panasonic DVD-RV31 Player Motherboard, Outer Case: passo 3, imagem 2 %32
    • Remove the three screws running along the back edge of case cover.
    • Remove the two screws from each side of the case cover.
  4. Removing Panasonic DVD-RV31 Player Motherboard: passo 4, imagem 1 %32
    • Grab edges of the cover with your hands. Pull outward slightly, then straight up.
  5. Removing Panasonic DVD-RV31 Player Motherboard, Front Panel: passo 5, imagem 1 %32 Removing Panasonic DVD-RV31 Player Motherboard, Front Panel: passo 5, imagem 2 %32
    • Lift up the five tabs securing the front panel to the chassis. There are three on the bottom, and two on the inside edges of the panel. Panel should then lift off the player.
  6. Removing Panasonic DVD-RV31 Player Motherboard, Motherboard: passo 6, imagem 1 %32 Removing Panasonic DVD-RV31 Player Motherboard, Motherboard: passo 6, imagem 2 %32
    • Remove the blue ribbon wire from its connector. When doing this, be cautious to not damage the connector.
    • Place forefinger under cable loop as shown, gripping with thumb.
    • Pull straight up. It should disconnect with little force.
  7. Removing Panasonic DVD-RV31 Player Motherboard: passo 7, imagem 1 %32 Removing Panasonic DVD-RV31 Player Motherboard: passo 7, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using tweezers or pliers, squeeze the tabs of the plastic fasteners together. While doing this, gently lift up on the motherboard until the fasteners are released.
  8. Removing Panasonic DVD-RV31 Player Motherboard: passo 8, imagem 1 %32
    • Remove the two screws securing the motherboard using a philips screw driver.
  9. Removing Panasonic DVD-RV31 Player Motherboard: passo 9, imagem 1 %32
    • Lift the board from the side closest to the front panel (top of photo).
    • Gently apply force until bottom connector releases from power board below.
Conclusão
Uma outra pessoa concluiu este guia.
Kevin
Membro desde: 04/26/11
375 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 18-20, Garner Spring 2011 Membro de Cal Poly, Team 18-20, Garner Spring 2011
CPSU-GARNER-S11S18G20
Membros da 4
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 3,237
