Ir para o conteúdo principal
Removing Nokia 3100b Keypad
  1. Removing Nokia 3100b Keypad, Battery: passo 1, imagem 1 %32
    • Make sure your phone is turned off.
  2. Removing Nokia 3100b Keypad: passo 2, imagem 1 %32
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
  3. Removing Nokia 3100b Keypad, Removing Nokia 3100b Keypad: passo 3, imagem 1 %32
    • Push the black tabs down and pull the colored half of the phone from the white half.
  4. Removing Nokia 3100b Keypad: passo 4, imagem 1 %32
    • The front part of the phone is now removed. Make sure nothing was damaged while removing the front cover.
  5. Removing Nokia 3100b Keypad: passo 5, imagem 1 %32
    • Remove the keypad membrane by pulling it from the front cover.
Conclusão
Equipe
Cal Poly, Team 29-64, Johann Spring 2010 Membro de Cal Poly, Team 29-64, Johann Spring 2010
CPSU-JOHANN-S10S29G64
3 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 70
Ao todo: 1,065
