Ir para o conteúdo principal
Removing Nikon Coolpix 4600 Front and Rear case
O que você precisa
  1. Removing Nikon Coolpix 4600 Front and Rear case, Front and Rear Case: passo 1, imagem 1 %32 Removing Nikon Coolpix 4600 Front and Rear case, Front and Rear Case: passo 1, imagem 2 %32
    • Locate the six screws on the outside of the camera (2 3.3 mm on the bottom, 2 5.25 mm on the left, and 2 5.25 mm on the right).
    • Using a Phillips 00 screwdriver, remove all of the six screws.
  2. Removing Nikon Coolpix 4600 Front and Rear case: passo 2, imagem 1 %32 Removing Nikon Coolpix 4600 Front and Rear case: passo 2, imagem 2 %32
    • Carefully pull the front and back case apart.
    • The front case is attached to internal components and cannot be removed independently.
  3. Removing Nikon Coolpix 4600 Front and Rear case: passo 3, imagem 1 %32
    • Look closely at the connection between the ribbon cable and the motherboard. Locate the two grey tabs on either side of the connecting bracket.
    • Slide the grey tabs toward the bottom of camera. Gently disconnect the ribbon cable from the motherboard.
    • After disconnecting the data ribbon, you can now separate the back case from the front case.
Conclusão
Nathan Sperling
Membro desde: 05/08/12
119 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 9-43, Regan Spring 2012 Membro de Cal Poly, Team 9-43, Regan Spring 2012
CPSU-REGAN-S12S9G43
Membros da 5
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 1,532
