Ir para o conteúdo principal
Removing Minolta X-370 Lens Holder
O que você precisa
  1. Removing Minolta X-370 Lens Holder, Minolta X-370 Battery Replacement: passo 1, imagem 1 %32 Removing Minolta X-370 Lens Holder, Minolta X-370 Battery Replacement: passo 1, imagem 2 %32
    • Flip the camera so that the bottom is facing you.
    • Take a spare coin and unscrew the battery cover off.
  2. Removing Minolta X-370 Lens Holder: passo 2, imagem 1 %32
    • Remove the batteries, making sure to note their proper alignment.
  3. Removing Minolta X-370 Lens Holder, Bottom Cover: passo 3, imagem 1 %32 Removing Minolta X-370 Lens Holder, Bottom Cover: passo 3, imagem 2 %32
    • Remove two 4.8mm screws.
    • Remove one 3.4mm screw.
    • Remove one 2.65mm screw.
    • Lift off the back cover.
  4. Removing Minolta X-370 Lens Holder: passo 4, imagem 1 %32
    • Remove three 3.5mm screws.
    • Remove two 3.8mm screws.
    • Remove one 6.35mm screw.
    • Remove one 4mm screw. Lift off the disk.
    • Remove one 5.11mm screw.
  5. Removing Minolta X-370 Lens Holder: passo 5, imagem 1 %32
    • Lift up the silver, metal piece
    • Please note that some internal pieces may come loose during this process.
  6. Removing Minolta X-370 Lens Holder, Lens Holder: passo 6, imagem 1 %32 Removing Minolta X-370 Lens Holder, Lens Holder: passo 6, imagem 2 %32 Removing Minolta X-370 Lens Holder, Lens Holder: passo 6, imagem 3 %32
    • Remove four 4.45mm screws and remove the alignment ring.
    • Remove the interior metal ring and the black plastic ring. Pay attention to the spring's location.
    • Pay attention to the alignment of the interior metal ring and the black plastic ring.
  7. Removing Minolta X-370 Lens Holder: passo 7, imagem 1 %32 Removing Minolta X-370 Lens Holder: passo 7, imagem 2 %32 Removing Minolta X-370 Lens Holder: passo 7, imagem 3 %32
    • Remove the two black stoppers.
    • Using the metal spudger, remove the two triangular hangers.
  8. Removing Minolta X-370 Lens Holder: passo 8, imagem 1 %32 Removing Minolta X-370 Lens Holder: passo 8, imagem 2 %32
    • Using the metal spudger, peel off the right leather cover.
    • Be careful not to tear the cover because you will need to use it again.
  9. Removing Minolta X-370 Lens Holder: passo 9, imagem 1 %32 Removing Minolta X-370 Lens Holder: passo 9, imagem 2 %32 Removing Minolta X-370 Lens Holder: passo 9, imagem 3 %32
    • Use the metal spudger to remove both the grip cover and the left leather cover.
    • Be careful not to tear the covers because you will need to use them again.
  10. Removing Minolta X-370 Lens Holder: passo 10, imagem 1 %32 Removing Minolta X-370 Lens Holder: passo 10, imagem 2 %32
    • Remove two 5.3mm screws.
    • Remove one 2.35mm screws.
  11. Removing Minolta X-370 Lens Holder: passo 11, imagem 1 %32 Removing Minolta X-370 Lens Holder: passo 11, imagem 2 %32
    • Remove the left and right plastic covers.
  12. Removing Minolta X-370 Lens Holder: passo 12, imagem 1 %32 Removing Minolta X-370 Lens Holder: passo 12, imagem 2 %32 Removing Minolta X-370 Lens Holder: passo 12, imagem 3 %32
    • Remove two 6.65mm screws.
    • Remove two 2.93mm screws.
    • Remove four 5.3mm screws.
    • Remove the black plastic lens holder.
Conclusão
4 outras pessoas executaram este guia.
Nick
Membro desde: 04/19/11
525 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 8-7, Regan Spring 2011 Membro de Cal Poly, Team 8-7, Regan Spring 2011
CPSU-REGAN-S11S8G7
Membros da 4
Autoria de 8 guias
Um comentário
I have Problems to assemble the new black plastic lens holder.
The space between camera Cup and the housing is very low.
Did someone have the same Problems ?
Klaus Kohlhas - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 13
Duração total: 7,200
