Ir para o conteúdo principal
Removing Lenovo Thinkpad T61p RAM
O que você precisa
  1. Removing Lenovo Thinkpad T61p RAM, RAM: passo 1, imagem 1 %32 Removing Lenovo Thinkpad T61p RAM, RAM: passo 1, imagem 2 %32
    • Place the laptop on a fat surface with the underside facing up
    • Remove the 4 Philips head screws.
    • Turn the computer over and open the display
    • Grasping each side of the palm rest, gently lift it off and rotate toward the front of the laptop
    • The palm rest will be connected to the main board by a ribbon cable
  2. Removing Lenovo Thinkpad T61p RAM: passo 2, imagem 1 %32
    • Disconnect the touchpad ribbon cable
    • This step is recommended in the service manual however it is possible to remove the RAM without discoinnecting the touchpad cable
  3. Removing Lenovo Thinkpad T61p RAM: passo 3, imagem 1 %32
    • Locate the RAM modules
    • Gently press the metal tabs outwards to release the top RAM module and remove it from the laptop
    • With the top RAM module removed you can release the lower RAM module in the same manner.
Conclusão
5 outras pessoas executaram este guia.
Glac1er
Membro desde: 05/25/13
180 Reputação
Autoria de 1 guia
Equipe
Glac1er Membro de Glac1er
Community
1 Membro
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 23
Duração total: 9,962
