Introdução
The brewgroup produces the coffee. The inner seals are heavy used and must be replaced from time to time.
O que você precisa
Lift out the coffee tray
Remove the lid sealing the coffee bean container
Remove all of the coffee beans you can possibly remove.
Pull the adjuster of the coffee bean grinder straight up
Remove the four T15 Torx screws
Remove the knob for the steam valve by simply pulling it off.
The front cover is secured with a Torx T15 screw. Remove it.
Pull the clamp from the connector.
Lift the elbow connector up from the drainage valve. You may need some force.
Remove the three Torx T15 screws, one on the lower left side, two on the lower right side.
Now the brew group can be removed. It is fixed on the upper edge with latches. First pull on the lower edge, then lower the brew group. You can remove it, wenn the latches on the upper edge come free.
For dissassembling and maintanace of the brew group use this guide.
For dissassembling and maintanace of the drainage valve use this guide.
Uma outra pessoa concluiu este guia.
Um agradecimento especial a esses tradutores:
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
