Ir para o conteúdo principal
Removing HP Compaq dx2000MT CPU Cooler
O que você precisa
  1. Removing HP Compaq dx2000MT CPU Cooler, Removing the HP Compaq dx2000MT Case Doors: passo 1, imagem 1 %32
    • Turn off your computer and remove the power cable by pulling it straight out of its socket.
  2. Removing HP Compaq dx2000MT CPU Cooler: passo 2, imagem 1 %32 Removing HP Compaq dx2000MT CPU Cooler: passo 2, imagem 2 %32
    • Remove the two Phillips #2 screws that secure the case door to the device.
  3. Removing HP Compaq dx2000MT CPU Cooler: passo 3, imagem 1 %32 Removing HP Compaq dx2000MT CPU Cooler: passo 3, imagem 2 %32 Removing HP Compaq dx2000MT CPU Cooler: passo 3, imagem 3 %32
    • Remove the side case door by pushing towards the rear of the device with your hand.
    • This may take considerable force so keep pushing!
    • Once you slide the door back, remove it by pulling it outwards from the device.
  4. Removing HP Compaq dx2000MT CPU Cooler: passo 4, imagem 1 %32 Removing HP Compaq dx2000MT CPU Cooler: passo 4, imagem 2 %32 Removing HP Compaq dx2000MT CPU Cooler: passo 4, imagem 3 %32
    • Once again, this may take considerable force.
  5. Removing HP Compaq dx2000MT CPU Cooler, Removing HP Compaq dx2000MT CPU Cooler: passo 5, imagem 1 %32 Removing HP Compaq dx2000MT CPU Cooler, Removing HP Compaq dx2000MT CPU Cooler: passo 5, imagem 2 %32
    • Remove the 3 pin power connector by pulling it towards the side of the device.
  6. Removing HP Compaq dx2000MT CPU Cooler: passo 6, imagem 1 %32 Removing HP Compaq dx2000MT CPU Cooler: passo 6, imagem 2 %32
    • Unscrew the 4 Torx T15 screws holding the CPU Cooler in place.
    • Make sure to hold your cpu cooler when removing the screws. You don't want it to fall!
  7. Removing HP Compaq dx2000MT CPU Cooler: passo 7, imagem 1 %32 Removing HP Compaq dx2000MT CPU Cooler: passo 7, imagem 2 %32
    • Remove the cpu cooler by pulling out towards the side of the device.
    • Make sure you do not touch where the cpu cooler makes contact with the processor! You could contaminate the layer of thermal paste that separates these components.
    • When replacing your cpu cooler, make sure you clean the processor contact area on the cooler and processor with isopropyl rubbing alcohol.
Conclusão
Logan Pace
Membro desde: 10/12/11
2.251 Reputação
Autoria de 9 guias
Equipe
Cal Poly, Team 17-16, Regan Fall 2011 Membro de Cal Poly, Team 17-16, Regan Fall 2011
CPSU-REGAN-F11S17G16
Membros da 4
Autoria de 17 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 16
Duração total: 5,509
