Ir para o conteúdo principal
Removing Front Panel/ Screen Logic Board
O que você precisa
  1. Removing Front Panel/ Screen Logic Board, Front panel/ Screen Logic Board: passo 1, imagem 1 %32
    • Using the plastic opening tool, pry off the top faceplate.
    • Place the tool in the small crack that runs along the side of the phone and pry.
  2. Removing Front Panel/ Screen Logic Board: passo 2, imagem 1 %32
    • Using the T6 Torx Screwdriver remove all 4 small screws.
  3. Removing Front Panel/ Screen Logic Board: passo 3, imagem 1 %32
    • Remove silver plate from phone.
  4. Removing Front Panel/ Screen Logic Board: passo 4, imagem 1 %32
    • Using the spudger remove the plastic camera casing
  5. Removing Front Panel/ Screen Logic Board: passo 5, imagem 1 %32
    • Using the iPod Opening Tool remove the yellow flex cable from the green logic board.
  6. Removing Front Panel/ Screen Logic Board: passo 6, imagem 1 %32
    • Use Spudger or hands to detach flex cable from front screen logic board
Conclusão
Cecilia
Membro desde: 04/11/10
1 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 27-96, Amido Spring 2010 Membro de Cal Poly, Team 27-96, Amido Spring 2010
CPSU-AMIDO-S10S27G96
4 Membros
Autoria de 15 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 21
Últimos 30 dias: 49
Ao todo: 2,076
