Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
The purpose of this guide is to demonstrate how to locate and remove the 1150 Wireless MiniPCI Card.
Peças
Nenhum componente especificado.
  1. Turn the laptop upside down and  locate the panel labeled C. Unscrew the single screw holding the cover in place. lift up the cover and remove it to exposed the Wireless MiniPCI Card.
    • Turn the laptop upside down and locate the panel labeled C.
    • Unscrew the single screw holding the cover in place.
    • lift up the cover and remove it to exposed the Wireless MiniPCI Card.
  2. Using a plastic spudger or similar, gently pry the grey and black wires off. The grey and black wires are the antenna wires so be careful not to damage them
    • Using a plastic spudger or similar, gently pry the grey and black wires off.
    • The grey and black wires are the antenna wires so be careful not to damage them
    • Gently pull the retaining clips away from the board so that the board pops up.
  3. Lift the board up and out of the mini PCI slot at an angle of about 35 - 45 degrees
    • Lift the board up and out of the mini PCI slot at an angle of about 35 - 45 degrees
Conclusão
Uma outra pessoa concluiu este guia.
Teja
Membro desde: 27/04/2010
98 Reputação
3 Guias de autoria
Equipe
Cal Poly, Team 16-2, Maness Spring 2010 Membro de Cal Poly, Team 16-2, Maness Spring 2010
CPSU-MANESS-S10S16G2
4 Membros
9 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 5,659
