Ir para o conteúdo principal
Removing Dell Inspiron 1150 RAM
O que você precisa
  1. Removing Dell Inspiron 1150 RAM, Removing Dell Inspiron 1150 RAM: passo 1, imagem 1 %32
    • Turn the laptop so that the bottom is facing up.
    • Locate the panel that has an M on it and two air vents.
  2. Removing Dell Inspiron 1150 RAM: passo 2, imagem 1 %32 Removing Dell Inspiron 1150 RAM: passo 2, imagem 2 %32
    • Take the screw driver and carefully unscrew the screw that is located above the M in order to remove the panel.
    • Put this screw in a bag or easily identifiable place.
    • Remove the panel.
  3. Removing Dell Inspiron 1150 RAM: passo 3, imagem 1 %32 Removing Dell Inspiron 1150 RAM: passo 3, imagem 2 %32 Removing Dell Inspiron 1150 RAM: passo 3, imagem 3 %32
    • After removing the panel, you will see two memory modules.
    • Locate the four spring clips that are holding the memory modules in place.
    • Place your thumb on each of the two spring clips for each memory module and push outward until the memory module pops up.
    • Gently raise the memory module and lift it out of its socket.
Conclusão
Christopher
Membro desde: 04/27/10
8 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 16-2, Maness Spring 2010 Membro de Cal Poly, Team 16-2, Maness Spring 2010
CPSU-MANESS-S10S16G2
Membros da 4
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 5,822
