Ir para o conteúdo principal
Removing DVD Drive from Acer Aspire 5100
O que você precisa
  1. Removing DVD Drive from Acer Aspire 5100, Removing DVD Drive from Acer Aspire 5100: passo 1, imagem 1 %32 Removing DVD Drive from Acer Aspire 5100, Removing DVD Drive from Acer Aspire 5100: passo 1, imagem 2 %32
    • Locate tab with battery symbol on back of laptop. Slide to left to eject battery.
  2. Removing DVD Drive from Acer Aspire 5100: passo 2, imagem 1 %32
    • Locate cover on back of laptop, diagonal to battery compartment. Remove four screws securing cover.
  3. Removing DVD Drive from Acer Aspire 5100: passo 3, imagem 1 %32 Removing DVD Drive from Acer Aspire 5100: passo 3, imagem 2 %32
    • After removing screws, carefully detach cover. You will see the cooling fan in the corner.
  4. Removing DVD Drive from Acer Aspire 5100: passo 4, imagem 1 %32 Removing DVD Drive from Acer Aspire 5100: passo 4, imagem 2 %32
    • Opposite the cooling fan is the component that contains the RAM card. Remove the screws holding the component in place. Carefully detach the component to expose the RAM card.
  5. Removing DVD Drive from Acer Aspire 5100: passo 5, imagem 1 %32
    • Locate the DVD drive and remove screw securing drive. Carefully push drive out from laptop.
Conclusão
To reassemble, follow above steps in reverse.
luis
Membro desde: 04/21/10
167 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 18-66, Johann Spring 2010 Membro de Cal Poly, Team 18-66, Johann Spring 2010
CPSU-JOHANN-S10S18G66
Membros da 5
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 16
Últimos 30 dias: 23
Duração total: 2,791
