Ir para o conteúdo principal
Removing Creative Zen Vision W Back Cover
O que você precisa
  1. Removing Creative Zen Vision W Back Cover, Battery Removal: passo 1, imagem 1 %32 Removing Creative Zen Vision W Back Cover, Battery Removal: passo 1, imagem 2 %32 Removing Creative Zen Vision W Back Cover, Battery Removal: passo 1, imagem 3 %32
    • Push the black button and slide the battery casing to the left simultaneously, until the battery is completely separated from the device.
  2. Removing Creative Zen Vision W Back Cover, Back Cover: passo 2, imagem 1 %32
    • Remove the 2 screws (3.5 mm) on the Compact Flash insert, located on the left hand side, with a Phillips #000 screwdriver.
  3. Removing Creative Zen Vision W Back Cover: passo 3, imagem 1 %32 Removing Creative Zen Vision W Back Cover: passo 3, imagem 2 %32
    • Remove the 5 screws (5.5 mm), circled in red, using a Phillips #0. Use a flashlight if necessary.
    • Peel off the sticker that says "Creative warranty void if broken" and remove the screw (5.5 mm) underneath with a Phillips #0.
    • Be careful, some of the screws are difficult to see and can be easily stripped.
  4. Removing Creative Zen Vision W Back Cover: passo 4, imagem 1 %32 Removing Creative Zen Vision W Back Cover: passo 4, imagem 2 %32 Removing Creative Zen Vision W Back Cover: passo 4, imagem 3 %32
    • Carefully pull the back cover off of the rest of the device.
    • The volume control buttons and power slider may fall off when removing the cover, do not lose these small pieces.
    • The USB input cover on the bottom of the device may also fall off.
Conclusão
Gabriele Pregadio
Membro desde: 04/17/13
1 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 17-2, Regan Spring 2013 Membro de Cal Poly, Team 17-2, Regan Spring 2013
CPSU-REGAN-S13S17G2
4 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Ao todo: 846
