Introdução
This is a step-by-step guide to remove the outermost shell and innermost shell to get inside the device for further repairs.
WARNING: In this guide, you will be cutting the warranty seals. Once warranty seals are broken, you may no longer return the product.
TIPS:
- Be sure to check the screwdriver heads before performing this task; otherwise, screws may become damaged.
- Use an ice cube tray or egg carton, place each screw in its own cup to organize the screws.
O que você precisa
Flip the Braven BRV-X upside down so you are facing the bottom side.
With the H1.5 Head Screwdriver, unscrew the four screws.
Using the #0 Phillips screwdriver, unscrew the four screws on the four corners of the bottom side.
Gently remove the outer casing, which should reveal the inner shell.
Uma outra pessoa concluiu este guia.
