Ir para o conteúdo principal
Removing Audio Technica ATH-AD500 Foam Disks
O que você precisa
  1. Removing Audio Technica ATH-AD500 Foam Disks, Speaker Assembly: passo 1, imagem 1 %32
    • Remove the ear pads by peeling them away from the grill.
  2. Removing Audio Technica ATH-AD500 Foam Disks: passo 2, imagem 1 %32
    • Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
  3. Removing Audio Technica ATH-AD500 Foam Disks: passo 3, imagem 1 %32
    • Remove the speaker from the grill by pulling it out.
    • Remove the speaker carefully so you do not rip the wires out.
  4. Removing Audio Technica ATH-AD500 Foam Disks, Foam Disks: passo 4, imagem 1 %32 Removing Audio Technica ATH-AD500 Foam Disks, Foam Disks: passo 4, imagem 2 %32
    • Remove the foam disk from the grill by peeling it away from the grill.
    • During reassembly, make sure that the speaker is angled into your ear canal.
Conclusão
Melanie Reis
Membro desde: 01/11/13
227 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 17-19, Forte Winter 2013 Membro de Cal Poly, Team 17-19, Forte Winter 2013
CPSU-FORTE-W13S17G19
Membros da 6
Autoria de 17 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 19
Duração total: 2,095
