Introdução
There are a number of components underneath the center console of the Acura Integra, and the entire console must be removed to access them.
This guide shows how to remove the center console from models with a manual transmission.
O que você precisa
Remove the two Phillips screws at the very rear of the center console near the floor.
Remove two Phillips screws from behind the ash tray.
Remove the lower portion of the console that contains the cigarette lighter from the rest of the center console.
Disconnect the electrical connector for the cigarette lighter by first depressing the tab on top, and then pulling directly out of the socket.
8 outras pessoas executaram este guia.
