Ir para o conteúdo principal
Removing 1985-1988 Volvo 740 Throttle Body
O que você precisa
  1. Removing 1985-1988 Volvo 740 Throttle Body, 1985-1988 Volvo 740 Preparing Car For Work: passo 1, imagem 1 %32 Removing 1985-1988 Volvo 740 Throttle Body, 1985-1988 Volvo 740 Preparing Car For Work: passo 1, imagem 2 %32
    • Firstly Disconnect battery
    • Always take the negative terminal off first.
    • '''General Tip After disconnecting the battery leave the car for about 10 mins , This lets any residual energy left in the electrical system to dissapate. It is good practise whatever the job
  2. Removing 1985-1988 Volvo 740 Throttle Body, Removing Throttle Body: passo 2, imagem 1 %32
    • Locate throttle body on right side of engine, it is between the intake tube and intake manifold.
  3. Removing 1985-1988 Volvo 740 Throttle Body: passo 3, imagem 1 %32
    • Locate throttle linkage cable assembly.
  4. Removing 1985-1988 Volvo 740 Throttle Body: passo 4, imagem 1 %32 Removing 1985-1988 Volvo 740 Throttle Body: passo 4, imagem 2 %32
    • Twist the assembly clockwise.
  5. Removing 1985-1988 Volvo 740 Throttle Body: passo 5, imagem 1 %32
    • Slide both slackened cables off assembly’s guides.
  6. Removing 1985-1988 Volvo 740 Throttle Body: passo 6, imagem 1 %32 Removing 1985-1988 Volvo 740 Throttle Body: passo 6, imagem 2 %32
    • Locate the two hoses on the top of the throttle body.
    • Gently lift the hoses off.
  7. Removing 1985-1988 Volvo 740 Throttle Body: passo 7, imagem 1 %32
    • Use a flat head screwdriver to loosen the hose clamp attaching the intake tube to the throttle body.
  8. Removing 1985-1988 Volvo 740 Throttle Body: passo 8, imagem 1 %32
    • Remove the intake tube from the throttle body.
  9. Removing 1985-1988 Volvo 740 Throttle Body: passo 9, imagem 1 %32
    • Locate wiring clip on the underside of the throttle body.
  10. Removing 1985-1988 Volvo 740 Throttle Body: passo 10, imagem 1 %32 Removing 1985-1988 Volvo 740 Throttle Body: passo 10, imagem 2 %32
    • Press down on the locking mechanism before gently removing the wiring clip.
  11. Removing 1985-1988 Volvo 740 Throttle Body: passo 11, imagem 1 %32 Removing 1985-1988 Volvo 740 Throttle Body: passo 11, imagem 2 %32 Removing 1985-1988 Volvo 740 Throttle Body: passo 11, imagem 3 %32
    • Locate throttle linkage arm.
    • Open the locking clip with a flat head screwdriver.
    • Pry off the linkage arm with a flat head screwdriver.
  12. Removing 1985-1988 Volvo 740 Throttle Body: passo 12, imagem 1 %32 Removing 1985-1988 Volvo 740 Throttle Body: passo 12, imagem 2 %32 Removing 1985-1988 Volvo 740 Throttle Body: passo 12, imagem 3 %32
    • Locate the three 13mm nuts attaching the throttle body to the intake manifold.
    • Remove nuts with a 13mm crescent wrench.
  13. Removing 1985-1988 Volvo 740 Throttle Body: passo 13, imagem 1 %32
    • Lift the throttle body off of the intake manifold.
    • The manifold is now out of the engine bay and ready for cleaning or adjustment.
Conclusão
Uma outra pessoa concluiu este guia.
Raymond
Membro desde: 10/11/10
76 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 3-28, Regan Fall 2010 Membro de Cal Poly, Team 3-28, Regan Fall 2010
CPSU-REGAN-F10S3G28
Membros da 4
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 12
Duração total: 4,572
