Introdução
How to take apart your 2013 Chromebook Pixel to remove the Write Protect Screw. This will allow you to install other operating systems natively.
O que você precisa
Flip your Chromebook Pixel over onto its back
Using a flat edge screwdriver, gently pull up to remove the rubber pads from the laptop to reveal the screws
Using a small Philips screwdriver, remove the four screws under the pads
Using a spudger (or another flat but slightly blunt object), gently pry the laptop open
You may find it helpful to start with a smaller (skinnier) head and work your way up to a larger size
Gently pull up from the front of the laptop and open it up like a clamshell
Locate the write protect screw
Remove it and you can begin flashing your BIOS!
Do I have to flash the bios when replacing the battery?
There is no need to flash the BIOS if all you want to do is replace the battery.
I want to install windows on to the chrome book pixel 2013 but i have concerns regarding the touch screen. Can you help? Is there any video that you have uploaded for the installation?
How to check if screw is already removed or not? By not opening its back.
15 outras pessoas executaram este guia.
4 comentários
removing this will allow me to boot and install windows?
It will allow you to install Windows to the main hard drive and boot to it, but! As of yet, there’s no way that I’ve found to get the trackpad working in Windows with the Chromebook Pixel.
You will find more information here:
Acer R752TN write protect screw location?
