Ir para o conteúdo principal
Remove and clean the Whirlpool dishwasher spray arm
O que você precisa
  1. Remove and clean the Whirlpool dishwasher spray arm, Spray arm: passo 1, imagem 1 %32 Remove and clean the Whirlpool dishwasher spray arm, Spray arm: passo 1, imagem 2 %32
    • Turn off the dishwasher.
  2. Remove and clean the Whirlpool dishwasher spray arm: passo 2, imagem 1 %32 Remove and clean the Whirlpool dishwasher spray arm: passo 2, imagem 2 %32 Remove and clean the Whirlpool dishwasher spray arm: passo 2, imagem 3 %32
    • Remove the lower rack.
  3. Remove and clean the Whirlpool dishwasher spray arm: passo 3, imagem 1 %32
    • Locate the lower spray arm.
  4. Remove and clean the Whirlpool dishwasher spray arm: passo 4, imagem 1 %32 Remove and clean the Whirlpool dishwasher spray arm: passo 4, imagem 2 %32 Remove and clean the Whirlpool dishwasher spray arm: passo 4, imagem 3 %32
    • Detach the lower spray arm by rotating the base counterclockwise.
  5. Remove and clean the Whirlpool dishwasher spray arm: passo 5, imagem 1 %32 Remove and clean the Whirlpool dishwasher spray arm: passo 5, imagem 2 %32 Remove and clean the Whirlpool dishwasher spray arm: passo 5, imagem 3 %32
    • Detach the top spray arm by rotating the base clockwise.
  6. Remove and clean the Whirlpool dishwasher spray arm: passo 6, imagem 1 %32 Remove and clean the Whirlpool dishwasher spray arm: passo 6, imagem 2 %32
    • Clean the spray arm with warm soapy water and a soft brush.
  7. Remove and clean the Whirlpool dishwasher spray arm: passo 7, imagem 1 %32 Remove and clean the Whirlpool dishwasher spray arm: passo 7, imagem 2 %32 Remove and clean the Whirlpool dishwasher spray arm: passo 7, imagem 3 %32
    • Rinse thoroughly and reattach the spray arm to the dishwasher.
    • The longer spray arm goes on the bottom and the shorter one on the top.
  8. Remove and clean the Whirlpool dishwasher spray arm: passo 8, imagem 1 %32
    • Run a cycle with hot water and a dishwasher cleaner to further clean the interior.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Eduardo Mola
Membro desde: 01/16/23
175 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 10
Últimos 7 dias: 83
Últimos 30 dias: 458
Duração total: 5,074
