Introdução
For many repairs to Siemens EQ devices (or BOSCH Vero), the side panel on the tank side must be removed. The process is similar for many models, an EQ7 is shown here.
O que você precisa
Remove all attachments such as water tank, pulp drawer, brew group.
Remove the coffee container lid and take out all the coffee beans.
Lay the machine on its side with the water tank side facing up.
The side panel is essentially held on the ground by five strong catches. Pry up the pegs with a strong prying tool. It's pretty difficult and you need a lot of strength.
If the catches are loose, you can pull the side panel away from below. But it's still stuck in other places.
Use a plastic tool to pry the top cover up a few millimeters and lift off the side panel. Most of the time it's still stuck, especially at the front edge, you have to pull hard.
Follow the steps in reverse order to reassemble your device.
Uma outra pessoa concluiu este guia.
Um agradecimento especial a esses tradutores:
100%
oldturkey03 está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
