Ir para o conteúdo principal
O que você precisa
  1. Remove Nintendo GameCube Optical Drive Assembly, Top Case: passo 1, imagem 1 %32 Remove Nintendo GameCube Optical Drive Assembly, Top Case: passo 1, imagem 2 %32 Remove Nintendo GameCube Optical Drive Assembly, Top Case: passo 1, imagem 3 %32
    • Turn over the Gamecube so that the bottom side is facing up.
    • Use the 4.5 mm Gamebit screwdriver to remove all four screws.
  2. Remove Nintendo GameCube Optical Drive Assembly: passo 2, imagem 1 %32 Remove Nintendo GameCube Optical Drive Assembly: passo 2, imagem 2 %32 Remove Nintendo GameCube Optical Drive Assembly: passo 2, imagem 3 %32
    • With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half.
    • Move the GameCube so that the inside is facing upwards.
  3. Remove Nintendo GameCube Optical Drive Assembly, Remove Nintendo GameCube Optical Drive Assembly: passo 3, imagem 1 %32 Remove Nintendo GameCube Optical Drive Assembly, Remove Nintendo GameCube Optical Drive Assembly: passo 3, imagem 2 %32
    • The left side of the unit contains the cooling fan and its housing.
    • Carefully remove the two screws attaching the cooling fan housing to the unit.
    • Do not detach the red and black cooling fan wire from the main unit. Boxed in orange.
  4. Remove Nintendo GameCube Optical Drive Assembly: passo 4, imagem 1 %32 Remove Nintendo GameCube Optical Drive Assembly: passo 4, imagem 2 %32
    • Remove the four Phillips #1 screws retaining the ground springs.
    • Carefully remove the ground springs from the main unit.
  5. Remove Nintendo GameCube Optical Drive Assembly: passo 5, imagem 1 %32 Remove Nintendo GameCube Optical Drive Assembly: passo 5, imagem 2 %32
    • The optical drive is secured to a metal plate.
    • Using a Phillips #2 screwdriver, unscrew the twelve screws that are around the outer edge of the optical drive.
  6. Remove Nintendo GameCube Optical Drive Assembly, Remove the assembly: passo 6, imagem 1 %32 Remove Nintendo GameCube Optical Drive Assembly, Remove the assembly: passo 6, imagem 2 %32 Remove Nintendo GameCube Optical Drive Assembly, Remove the assembly: passo 6, imagem 3 %32
    • Carefully separate the optical drive assembly from the rest of the GameCube unit.
    • The optical drive assembly is secured to the motherboard underneath by a slot; some force may be required to carefully free the assembly.
    • The metal plate and the actual optical drive will remain attached.
Conclusão
dcarlin
Membro desde: 05/11/2009
295 Reputação
4 Guias de autoria
Equipe
Cal Poly, Team 6-2, Maness Fall 2009 Membro de Cal Poly, Team 6-2, Maness Fall 2009
CPSU-MANESS-F09S6G2
4 Membros
39 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 4,353
