Ir para o conteúdo principal
Remove Lower Case
O que você precisa
  1. Remove Lower Case, Remove screws from bottom of laptop.: passo 1, imagem 1 %32 Remove Lower Case, Remove screws from bottom of laptop.: passo 1, imagem 2 %32
    • Flip the computer over to access the screws on the bottom.
    • Remove 8 black, 7mm PH0 screws (M2 x L7).
    • Note: Virtually all the other screws for this computer are PH1 screws which may get stripped when using a smaller screwdriver, but these screws require a Philips PH0 driver.
    • Pry up the clips/latches and then remove the lower case. Start at the front (four clips), then sides (three clips each side) and back (four clips) - there is also one clip in the middle of the case.
Conclusão
johann beda
Membro desde: 09/13/10
3.428 Reputação
Autoria de 15 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Ao todo: 75
