Ir para o conteúdo principal
Remove IBM WorkPad c3 Battery
O que você precisa
  1. Remove IBM WorkPad c3 Battery, Back Case: passo 1, imagem 1 %32 Remove IBM WorkPad c3 Battery, Back Case: passo 1, imagem 2 %32
    • Turn the device over so that the screen is facing down.
    • In the next step the device will be heated, so the screen must be turned over to prevent heat damage to the LCD/Digitizer.
  2. Remove IBM WorkPad c3 Battery: passo 2, imagem 1 %32
    • Using a hair dryer, slowly heat the edges of the WorkPad.
    • Spend at least one minute heating each side of the device. This will melt the glue holding the case together, and allow it to be removed.
    • Be sure not to touch the device directly after heating as it will be extremely hot. Use a towel or oven mitt to grab it.
  3. Remove IBM WorkPad c3 Battery: passo 3, imagem 1 %32 Remove IBM WorkPad c3 Battery: passo 3, imagem 2 %32
    • Use a plastic opening tool to pry the back case from the WorkPad.
    • If the rear cover is not coming off very easily, you probably need to reheat the case in order to sufficiently melt the glue.
  4. Remove IBM WorkPad c3 Battery, Battery: passo 4, imagem 1 %32
    • Remove the yellow tape that is covering the battery connector
  5. Remove IBM WorkPad c3 Battery: passo 5, imagem 1 %32
    • Using the tweezers, carefully disconnect the battery cable from the port
  6. Remove IBM WorkPad c3 Battery: passo 6, imagem 1 %32 Remove IBM WorkPad c3 Battery: passo 6, imagem 2 %32
    • Using the plastic opening tools, lift the battery out of the case
    • The battery is secured with adhesive and it will take some effort to remove
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 21-35, Regan Fall 2010 Membro de Cal Poly, Team 21-35, Regan Fall 2010
CPSU-REGAN-F10S21G35
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 30
Duração total: 4,192
