Introdução
This guide is for either replacing the receiver jack/plug or removing parts that have broken off inside the headphones from a plug. Please read it through and make sure you are comfortable with it before attempting the teardown.
O que você precisa
Place the headphones down with ear cushions facing you
Cushions are held in by small tabs along the perimeter. Remove by hand
Pad is held in by two pieces of double-sided tape. You only need to peel back the left piece, as shown
Be careful to avoid tearing the pad
First, remove the two small philips screws securing the backplate to the body
Turn the headphones over and carefully wiggle the backplate away from the body. Use soft plastic tools if necessary to avoid scratching the plate
Remove the two small, shorter philips screws securing the board to the body
The board is now held in by vinyl tape (black) and two ribbon cables
If you are just removing broken plug pieces, do not disconnect these ribbon cables - be careful not to damage them! Instead, simply lift the board enough to poke tweezers or similar through the plug to dislodge broken bits
If replacing the plug, disconnect the ribbon cables (one is soldered in place) from the circuit board and replace the board
Reassembly is the reverse of disassembly - no surprises. Optionally, replace your ear cushions, pads, or double sided tape in the process.
5 outras pessoas executaram este guia.
4 comentários
This guide was also useful to push back the pins of the headphone jack, as the plug got loose with the Gaming mic attachment.
Does that work for a lose 2.5 mm plug that it’s not making correct contact?
Where do we even get another receiver plug?
