Introdução
For the official iFixit guide to replace your 6s Plus screen, click here.The guide you are viewing is retained solely for historical purposes.
O que você precisa
Shut down the phone and remove the bottom screw
Alice stick with the screen out of the three sides,gently pull down the screen ,and then you can open the screen.
To maintain the 90-degree position, remove the five screws shown in the circle, be sure to place in accordance with the original location.
Remove the cover of the front camera and the earpiece. Screw position is still in the distance without interference as the original place away.
Unplug the front camera and remove the handset
Remove the home key and metal,around home button is glue, if the computer is open, on the cooling mouth blowing,can push it behind
7 outras pessoas executaram este guia.
2 comentários
Why in the !&&* are you doing this on carpet? Let me guess, only 9 of 10 screws went missing. Please Don't tell me it so it doesn't slip and slide around, just flip a mouse pad over
Maybe I should not do this on the carpet, but my screws are intact.
rootmi -
