Ir para o conteúdo principal
Removal/Replacement of Dell Inspiron E1705 Hard Drive
O que você precisa
  1. Removal/Replacement of Dell Inspiron E1705 Hard Drive, Battery: passo 1, imagem 1 %32
    • Make sure that the computer is turned off and is disconnected from external power source.
    • Turn it upside down and locate the battery release switch.
  2. Removal/Replacement of Dell Inspiron E1705 Hard Drive: passo 2, imagem 1 %32 Removal/Replacement of Dell Inspiron E1705 Hard Drive: passo 2, imagem 2 %32
    • While holding the switch in the open position, lift out the battery.
    • If you plan to work on any internal laptop components, press and hold the power button for 5 seconds. This will dissipate any residual charge on the motherboard to prevent electrical shock when you begin to handle it.
  3. Removal/Replacement of Dell Inspiron E1705 Hard Drive, Hard Drive: passo 3, imagem 1 %32 Removal/Replacement of Dell Inspiron E1705 Hard Drive, Hard Drive: passo 3, imagem 2 %32
    • Remove the two Phillips #1 screws on the left side of the computer, just above the battery compartment.
    • These screws hold the hard drive tray into the hard drive compartment.
  4. Removal/Replacement of Dell Inspiron E1705 Hard Drive: passo 4, imagem 1 %32
    • Slide the hard drive tray out of the hard drive compartment.
Conclusão
3 outras pessoas executaram este guia.
Malik Shahbal
Membro desde: 10/05/10
471 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 22-5, Maness Fall 2010 Membro de Cal Poly, Team 22-5, Maness Fall 2010
CPSU-MANESS-F10S22G5
Membros da 4
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 28
Duração total: 20,320
