Introdução
This guide will provide simple instructions for the removal of the outer casing of the TiVo Series 2. This may be necessary for interior part replacement or cleaning. The only tool needed for this tear-down is a T10 Torx or similar star bit screwdriver.
O que você precisa
Power down the TiVo and detach the power cable from the rear of the unit.
Lift up and pull back the outer casing towards the rear of the unit.
I have the TiVo Series 2 model TCD746500 and the procedure for replacing a fan on my model is almost identical to the procedure described here, with one significant difference at this step: first pull/slide the outer casing back towards yourself and only thereafter pull it up.
