Ir para o conteúdo principal
Ferramentas utilizadas neste teardown
Introdução
This guide will provide simple instructions for the removal of the outer casing of the TiVo Series 2. This may be necessary for interior part replacement or cleaning. The only tool needed for this tear-down is a T10 Torx or similar star bit screwdriver.
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua TiVo Series 2 TCD540080, use o nosso manual de serviço.
  1. Power down the TiVo and detach the power cable from the rear of the unit.
    • Power down the TiVo and detach the power cable from the rear of the unit.
    • Wait 5 minutes for the unit to fully discharge before proceeding to the next step.
  2. Remove the five T10 screws from the rear of the case using the Torx screwdriver.
    • Remove the five T10 screws from the rear of the case using the Torx screwdriver.
  3. Lift up and pull back the outer casing towards the rear of the unit. Lift up and pull back the outer casing towards the rear of the unit.
    • Lift up and pull back the outer casing towards the rear of the unit.
Svyatoslav Markeyev
Membro desde: 16/04/2010
135 Reputação
5 Guias de autoria
Equipe
Cal Poly, Team 33-79, Johann Spring 2010 Membro de Cal Poly, Team 33-79, Johann Spring 2010
CPSU-JOHANN-S10S33G79
4 Membros
5 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 4,364
