Ir para o conteúdo principal
Remington S5500 Power Supply Cable Removal
O que você precisa
  1. Remington S5500 Power Supply Cable Removal, Power Supply Cable: passo 1, imagem 1 %32 Remington S5500 Power Supply Cable Removal, Power Supply Cable: passo 1, imagem 2 %32
    • Place the prying tool in between the hair straightener and the aligning cap.
    • Push forwards on the prying tool to pop off the aligning cap.
  2. Remington S5500 Power Supply Cable Removal: passo 2, imagem 1 %32 Remington S5500 Power Supply Cable Removal: passo 2, imagem 2 %32 Remington S5500 Power Supply Cable Removal: passo 2, imagem 3 %32
    • Remove the screws with the Phillips #1 screwdriver located underneath the aligning cap, one on each side of the straightener.
    • Use the prying tool to remove the aligning rods after the removal of the screws.
    • Gently separate each half of the hair straightener.
    • The spring located in the middle of this mechanism may pop out and can get lost very easily. Try to separate the two components slowly.
  3. Remington S5500 Power Supply Cable Removal: passo 3, imagem 1 %32 Remington S5500 Power Supply Cable Removal: passo 3, imagem 2 %32
    • After the hair straightener is separated, use a Phillips #1 screwdriver to remove the two screws located on the lower half of the straightener.
    • Use the prying tool to remove the hinge cover.
  4. Remington S5500 Power Supply Cable Removal: passo 4, imagem 1 %32 Remington S5500 Power Supply Cable Removal: passo 4, imagem 2 %32
    • Pull upwards while pulling outwards to disconnect the wire from the housing.
Conclusão
Benjamin Yohe
Membro desde: 07/11/18
303 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S3-G3, Wilson Summer 2018 Membro de IUPUI, Team S3-G3, Wilson Summer 2018
IUPUI-WILSON-SU18S3G3
Membros da 5
Autoria de 2 guias
6 comentários
Excelente trabajo! Muchas gracias por la información!
Ronnetto - Responder
is there a place where you can buy and replace the power cable, or the plug ?
alexandru popa - Responder
the slip ring plug that is ..
alexandru popa -
Hello,
from where did you get the spare power cord ?
Kes - Responder
part number would be helpful?
Steven Lamprell - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 45
Duração total: 7,260
