Introdução
Diese Anleitung zeigt dir, wie du deine EarPods reinigen kannst
O que você precisa
Falls deine EarPods durch Staub, Wachs (oder andere Partikel) verschmutzt sind, folge den Schritten dieser Anleitung, um sie zu reinigen.
Denke daran, deine EarPods 10 Minuten lang trocknen zu lassen.
85 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
100%
Matthias Huisken está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
31 comentários
Best way is clean the larger part with a earbud. The smaller doesnt make that much sound. Blow air onto the larger part after cleaning.
I use a cotton swab (q-tip). First a dry one, then I blow into all openings, next I use a damp (not dripping) q-tip (alcohol, saliva) to remove remaining wax, dirt. There are four opening on each earbud. I clean them all.
With saliva? You &&^&^$ disgusting.
GROSS Saliva? yuck
what the &&^& is wrong with you
