Ir para o conteúdo principal
Refresh, Reset, Start-up repair from USB recovery media
Vídeo de Apresentação
  1. Refresh, Reset, Start-up repair from USB recovery media, Refresh, Reset, Start-up repair from USB recovery media: passo 1, imagem 1 %32 Refresh, Reset, Start-up repair from USB recovery media, Refresh, Reset, Start-up repair from USB recovery media: passo 1, imagem 2 %32 Refresh, Reset, Start-up repair from USB recovery media, Refresh, Reset, Start-up repair from USB recovery media: passo 1, imagem 3 %32
    • - Make Surface turned off and plugged in.
    • - Insert the USB recovery drive into the USB port.
    • - Press and hold the Volume Down button, press the Power button in a short time.
    • - When the Surface logo appears, release the Volume button.
    • - Select the language and keyboard layout.
  2. Refresh, Reset, Start-up repair from USB recovery media: passo 2, imagem 1 %32 Refresh, Reset, Start-up repair from USB recovery media: passo 2, imagem 2 %32 Refresh, Reset, Start-up repair from USB recovery media: passo 2, imagem 3 %32
    • Now you are in the Advanced Startup Options menu. You can choose from:
    • - Refresh your PC
    • - Reset your PC
    • ...or from Advanced options menu:
    • - Start-up repair
    • - Command prompt
Conclusão
8 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
191.278 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.528 guias
3 comentários
Hello.my surface rt is not working properly.The windows is on and off.What should i do?
Muzahar - Responder
Hello.My surface rt is not working properly.
The windows display is on and off. What should i do to prenvent it?
Muzahar - Responder
Hello!
RT is not working properly ! I have Surface RT arm and no eny possibility to come in to uefi even I press upp vol. and press on. The tablet will no start and will not to be able on for around 3 \4 minutes. The USB with the windows is it in but when I tray to start with vol down and press on not working like the video shwoing. :(
pigi01se - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 5,576
