Ir para o conteúdo principal
Reemplazo de la batería de MacBook Pro de 15 pulgadas Unibody de fines de 2008 y principio de 2009
O que você precisa
  1. Reemplazo de la batería de  MacBook Pro de 15 pulgadas Unibody de fines de 2008 y principio de 2009, Puerta de acceso: passo 1, imagem 1 %32 Reemplazo de la batería de  MacBook Pro de 15 pulgadas Unibody de fines de 2008 y principio de 2009, Puerta de acceso: passo 1, imagem 2 %32
    • Con el estuche cerrado, coloca el Unibody boca arriba sobre una superficie plana.
    • Presiona el lado ranurado del pestillo de liberación de la puerta de acceso lo suficiente para agarrar el extremo libre. Levanta el pestillo de liberación hasta que quede vertical.
    The A1286 has no Access Door.!!
    I actually can see no sign of the battery!...
    aguib - Responder
    Citação de aguib:
    I assume you have the newer model, with the built-in battery. It's still removable with tools, but these are the wrong instructions for that model.
    lgc90 - Responder
    when will there be a guide for the other unibody macbook pro. that does not have an access door?
    irishking - Responder
    Is there a manual to show, how disasembly the display, i mean, after step 5, to check the display between lcd and aluminiun back case?
    Max
    Max - Responder
    On other guides you state the height of the HD that can be supported, e.g. MacBook Pro 15" Core 2 Duo Model A1211 Hard Drive Replacement , I have read ( but have not confirmed ) that the uni-body MacBook Pro can be fitted with the 750GB and 1TB 12mm drive from Western Digital.
    Can you confirm this?
    Many thanks in advance.
    ahothabeth - Responder
    Citação de SHerwood Ball:
    My display and aluminum casing has separated.
    I don't know if it just snaps back together or does it need to be glued.
    I dropped mine on the carpeted stairs and the display still works.
    I'm hoping I can just snap it back together and that no plastic pieces or teeth of the snapping
    portion have been broken........
    SHerwood Ball - Responder
    When you say "left fan" is this "left when looking at the logic board after turning the computer over and looking it up opening it up" or "left when sitting at the computer keyboard and typing on it"?
    thvv - Responder
    We always use left and right in reference to the computer when you're using it.
    Andrew Optimus Goldheart -
    Directions were great and the worn dc in board was replaced. The hardest part of the procedure is disconnecting the data display cable. A better description of step 21 is to slide the connector parallel to the circuit board towards the outside corner. Reconnecting correctly took several tries.
    I used the tip of the spudger to nudge the corners a little at a time to seat the connector.
    The ribbon connector for the keyboard has to be inserted all the way before seating the retaining cap. It took me three tries . First try power button did not work second try numbers keys did not work.
    Thanks for the directions ...could not have done it with out them!!!
    landryd - Responder
    Hola. Poseo un MacBook Pro Late 2008 y debo cambiarle las cornetas. Me sirve unas cornetas de un MBP Late 2011?
    jegonzalez80 - Responder
    Please read the instructions about removing the bluetooth cable - you CAN work around it, and NOT take off the plug.
    kenneth krabat - Responder
  2. Reemplazo de la batería de  MacBook Pro de 15 pulgadas Unibody de fines de 2008 y principio de 2009: passo 2, imagem 1 %32
    • La puerta de acceso ahora debe estar lo suficientemente levantada para levantarla y sacarla del Unibody.
  3. Reemplazo de la batería de  MacBook Pro de 15 pulgadas Unibody de fines de 2008 y principio de 2009, Battery: passo 3, imagem 1 %32
    • Asegúrate de que el pestillo de liberación de la puerta de acceso esté vertical antes de continuar.
    • Agarra la lengüeta de plástico translúcido y extrae la batería de la Unibody.
    • Si se presiona el pestillo, se bloqueará la batería en su lugar.
    Do I need to wait for the battery to charge completely before using the computer (while plugged in)?
    Kaila Potts - Responder
    No. You do not need to charge it completely before removing it.
    Titus (#1579) - Responder
Conclusão
Para volver a ensamblar tu dispositivo, sigue estas instrucciones en orden inverso.
84 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
en es
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
3 comentários
I recently replaced my battery for the macbook pro late 2008 model number A1281, I have a weared problem with that - System shuts down while connected to power when it is Turned On.
I tried NVRAM reset also but no luck, Any help on this would be appreciable.
Thanks
Kamalarajan
Kamalarajan - Responder
Have just received the A1281 replacement battery. However it does not charge. The magsafe light is on green but the battery is not charging. When I put in my old battery the magsafe goes to amber and it starts to charge. Any ideas?
domburton - Responder
I just bought a new battery to replace A1281, and I have the same issue as you : the battery is not charging, power charger light is green.
I've tried to reset SMC, but it didn't solve anything.
Rodac -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 35
Últimos 30 dias: 121
Duração total: 84,535
