Ir para o conteúdo principal
Reely Carbon Fighter Brushless Motorritzel Replacement
O que você precisa
  1. Reely Carbon Fighter Brushless Motorritzel Replacement, trim loss: passo 1, imagem 1 %32
    • These two pins must be removed.
  2. Reely Carbon Fighter Brushless Motorritzel Replacement: passo 2, imagem 1 %32
    • Here, a screwdriver or other stable thin object (in the picture: letter opener) can be helpful
  3. Reely Carbon Fighter Brushless Motorritzel Replacement: passo 3, imagem 1 %32 Reely Carbon Fighter Brushless Motorritzel Replacement: passo 3, imagem 2 %32
    • TIP: if you remove the cladding more often (for example, for thorough cleaning), it may be helpful to provide the splints with some insulating tape, so the use of tools is unnecessary
  4. Reely Carbon Fighter Brushless Motorritzel Replacement: passo 4, imagem 1 %32
    • The panel is now dismantled
  5. Reely Carbon Fighter Brushless Motorritzel Replacement, pinion: passo 5, imagem 1 %32
    • If there is an additional main sprocket and engine sprocket protection (not serial condition), this must be removed first. To do this, all marked screws must be turned out with a PH1 screwdriver. These are two different screws.
    • When the vehicle is in the delivery state, only the red marked screw has to be removed.
  6. Reely Carbon Fighter Brushless Motorritzel Replacement: passo 6, imagem 1 %32
    • Then remove the red marked screw (PH1) on the underside (hold the green marked part),
    • to take out the green marked column / column.
  7. Reely Carbon Fighter Brushless Motorritzel Replacement: passo 7, imagem 1 %32
    • To loosen the pinion, the grub screw that fixes it to the motor output shaft must be loosened. For this you need a 1.5mm Imbus.
    • The rod to adjust the fall on the right rear wheel (direction of travel) should be solved on the vehicle side to remove the old part better (in the photo already done) and the new one to lead.
    • Then it can simply be pulled back and removed
  8. Reely Carbon Fighter Brushless Motorritzel Replacement: passo 8, imagem 1 %32 Reely Carbon Fighter Brushless Motorritzel Replacement: passo 8, imagem 2 %32
    • When pushing the new part onto the shaft, please note that it has a flattened side. At this the grub screw (marked in green) should rest.
  9. Reely Carbon Fighter Brushless Motorritzel Replacement: passo 9, imagem 1 %32
    • Then the distance of the two gears to each other should be adjusted correctly. Too big a game makes sure that the teeth consume early, with too little play it can not be turned anymore.
    • To adjust, slightly open the green marked screw and tilt the motor in the desired direction.
Conclusão
Please dispose of the old part properly! Best in the metal container on the recycling center, so it can be recycled. It has nothing to do with household waste. Work the steps in reverse order to reassemble the vehicle.
Um agradecimento especial a esses tradutores:
de en
100%
irlanda está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Leonard Kesting
Membro desde: 08/14/16
1.229 Reputação
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 21
Duração total: 1,896
