Ir para o conteúdo principal
Redragon K552 Key Switch Replacement
O que você precisa
  1. Redragon K552 Key Switch Replacement, Key Switch: passo 1, imagem 1 %32 Redragon K552 Key Switch Replacement, Key Switch: passo 1, imagem 2 %32 Redragon K552 Key Switch Replacement, Key Switch: passo 1, imagem 3 %32
    • Unplug the keyboard from the computer.
    • Because this keyboard does not use a detachable cable, you will have to detach the cable from the PC directly.
    • The location of the cable depends on how you had installed the keyboard into the PC. (In my case, I have it installed on the rear of my PC next to my ethernet cable).
    • RGB lights indicate that power is running through the keyboard.
    • Make sure that no power is running through the keyboard during the replacement process.
  2. Redragon K552 Key Switch Replacement: passo 2, imagem 1 %32 Redragon K552 Key Switch Replacement: passo 2, imagem 2 %32 Redragon K552 Key Switch Replacement: passo 2, imagem 3 %32
    • Align the keycap puller to the keycap.
    • Use the keycap puller to pull out all the keycaps from the keyboard.
  3. Redragon K552 Key Switch Replacement: passo 3, imagem 1 %32 Redragon K552 Key Switch Replacement: passo 3, imagem 2 %32 Redragon K552 Key Switch Replacement: passo 3, imagem 3 %32
    • Dip cotton swabs into a bottle of rubbing alcohol solution.
    • Clean the keycaps using the cotton swabs.
  4. Redragon K552 Key Switch Replacement: passo 4, imagem 1 %32 Redragon K552 Key Switch Replacement: passo 4, imagem 2 %32 Redragon K552 Key Switch Replacement: passo 4, imagem 3 %32
    • Dip another cotton swab into the rubbing alcohol solution.
    • Carefully use the cotton swab to clean the surface and crevices of the keyboard.
    • Do not drop rubbing alcohol into the keyboard directly as it may cause damage to the keyboard.
  5. Redragon K552 Key Switch Replacement: passo 5, imagem 1 %32 Redragon K552 Key Switch Replacement: passo 5, imagem 2 %32 Redragon K552 Key Switch Replacement: passo 5, imagem 3 %32
    • Align the switch puller with the faulty key switch.
    • Pull the faulty key switch straight up from the keyboard.
  6. Redragon K552 Key Switch Replacement: passo 6, imagem 1 %32 Redragon K552 Key Switch Replacement: passo 6, imagem 2 %32 Redragon K552 Key Switch Replacement: passo 6, imagem 3 %32
    • Align the pins of the new switch to the keyboard.
    • Press the key switch on the keyboard until it clicks into place.
  7. Redragon K552 Key Switch Replacement: passo 7, imagem 1 %32 Redragon K552 Key Switch Replacement: passo 7, imagem 2 %32 Redragon K552 Key Switch Replacement: passo 7, imagem 3 %32
    • Replace all of the keycaps.
  8. Redragon K552 Key Switch Replacement: passo 8, imagem 1 %32 Redragon K552 Key Switch Replacement: passo 8, imagem 2 %32 Redragon K552 Key Switch Replacement: passo 8, imagem 3 %32
    • Plug the keyboard USB cable back to the PC.
    • Use a keyboard tester online to test your key switches.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Lyxander Blanco
Membro desde: 03/19/22
187 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 35
Últimos 30 dias: 158
Duração total: 6,720
